Help with Antenna Setup for 119W
Username: Syl09
I just got my dish angle changed to 119W and need help with the Antenna Setup. I have viewsat ultra and WAS catching dish network channels.
P.S. Does IPL come on any 119W ch.
Thanks.
Username: Dimwitt
Post Number: 1251
The settings will be the same as the other sat you were aimed at.
You would select sat 119, input your lnb type and i assume you only have one lnb, diseqc port would be none.
Username: Syl09
I tried it all, but nothing happening.
please post specific TP Freq. I am located in southeast Georgia, U.S.
Username: Ricocossan
Post Number 689
TP 226-3179
Username: Plymouth
Post Number: 8849
Eric
LNB Type: standard
LNB Freq: 11250
Tp Freq: 12224
Diseq: If you use a switch set: port 1 and hook this LNB on port1 on switch.
Username: Roism
Irvine haoo, CA USA
Is TNT down on Dish?
Username: Satopia
Post Number: 376
eric im in southeast ga also if your close by i may can help u out
