hi nalin i did downloded the fawank7 lazmabin211 but cant scan any channels i did the autoroll. set defaltkeys/ blind scan/ tp scan/ every thing i did but no luck
hi playmouth\ how are you thanx for all ur help man but u no wat i still cant scan any channels on my pansat i downloded the echo3ku its working great on only desi /indian channels wen i try to download the echo7 and 8.10 nothing is happning i cant downlod the american channels i did the tp/advn/blind/ scan but nothing is working
HI PLYMOUTH soryy to bother u again and again i belive u help me alot with those bins but i still dont get it y? mt indian chanles are working fine on echo3 but wen i switch back to do sacn on echo7 or echo8.10 i dont see any thing i tried every thing may its my cable or my other dish is not working i dont have any signal or quality..... on both echos 7/8/ i have two dishes one for international and the other one is for local... international is working fine ... i have pansat 2500a it was converted to 2700 i did downloded the new lazma bin 211v3 but still no luck can any one help me plz thanx
Zia; If you have two dishes, there HAS to be a switch. You will be constantly groping in the dark, unless you post from your reciever settings, the information for each antenna, i.e.
1. for 119W Echo 7 2. for 110W Echo 10/11 3. for 61.5W Echo 3
AND you will be wasting Plymouth's and other helpers' time
