Pansat 2500 keeps freezing..
Username: Legend_killer
Post Number: 128
I was just doing a scan, and then on 3% it just froze and turned off and now its beeping like its trying to turn back on but won't.
this always used to happen when i used this pansat, it keeps turning off every couple of minutes.
Username: Lroy
Post Number: 463
Use this bin Nikk_Mty_Jvvh-Team-PUFF_(Lzma)_V211_V3.bin and your problem should be solved....
Username: Desi_munda
Post Number: 228
why u r scanning? i think the dish is down.
Post Number: 136
i cant find it, i was scanning my 119 dish for channels.
Username: Plymouth
Post Number: 8722
Ali
You can find all files here:
http://currentbins.com/ftafiles/
Post Number: 137
will it stop all the freezing and shutting off on me and not turning on?
Username: Plymouth
Post Number: 8724
Ali
What do you mean by "shutting off on me and not turning on"
Post Number: 139
like it shuts off and then obviously then the receiver turn on again but when it tries to it just freezes there, so it doesnt turn on, and you gotta turn off/on from the back panel numerous times to finally get it on without it freezing on the turning on point.
Username: Getmo96
Post Number: 105
I think Hussain just watches po rn....
"I think dish is down"
Username: Realdio
Monterrey, Nuevo Leon Mexico
Post Number: 131
someone can see Outdoor Channel
Username: Plymouth
Post Number: 8735
Leo
This channel is up on Echo 7
Outdoor Echo 7 # 153 Tp 12501 20000 H 5/6 v6946 a6847 p6946 UP!
