Can't get few channels on 119, please help
Username: Jerkisland
Post Number: 99
Few of the channels namely USA network, Disney Channel East, Food Network and few others are not coming up, I used to get them all before now I don't. Signal Strength is 78 and quality is 61
My Antenna settings are listed below
Setting for EchoStar 7 - 119W:
LNB Power: On
LNB Type: OCS-DP
LNB Freq: 11250
22KHz: Off
TP Freq: 12224
DiSEq: 1
Motor: Off
Legacy: None
I tried scan manually one of the TP 12399 and 12384 but it didn't catch any channels. Can someone help please.
Username: Gladiator34
Post Number: 64
set your lmbs to standard and you are up and running ...
Post Number: 65
is all the channels still there from 119 ?
Post Number: 100
Didn't work. Yes, I do get the channels.
Username: Plymouth
Post Number: 8578
DumDude
Try without switch, your switch can be blowed.
Post Number: 101
I don't have Switch. It is direct connection.
Username: Plymouth
Post Number: 8581
DumDude
List your receiver and dish(Dp or not)
Post Number: 102
Viewsat Xtreme
Dish 1000, it is a DP.
I also have 110 and 61.5 from which I receive all the channels that are on N2. The problem is with 119. I receive only few channels from 119, the ones I get are the local like ABC, CBS etc.
Username: Plymouth
Post Number: 8582
How is the quality?
Post Number: 103
Quality is at 61 and sometime goes to 80
Username: Plymouth
Post Number: 8583
The channels is autoroll or you can't get signal?
Post Number: 104
They are on the autoroll. The signal strength is 78 but the quality for those chan jumps from 0-20, making the picture to freeze or it displays searching for signal when no quality
Username: Plymouth
Post Number: 8584
DumDude
Reload the latest bin, sometime it work on Viewsat.
I'm again on 05 march 2009 bin with VS Ultra, when it autoroll, I reload this bin and all come back.
Post Number: 105
I already tried loading new bin again. Even did a factory reset and loaded the new bin but same results. I will try load the mar05 2009 bin and see if that works.
Username: Plymouth
Post Number: 8586
DumDude
Forget it, the latest bin work fine on your box.
Try it:
Go in Menu
System information
Code Menu
Select Nagra
Down arrow then select 00 01 00,01 01 00 and 01 06 00 and delete those 3 dish provider with "F3" on remote and load latest bin file, save and exit, wait on a channel until the autoroll found keys , it will take 5 to 15 minutes.
Post Number: 106
You mean delete the 3 dish provider keys, save and exit and then load the latest bin?
Username: Plymouth
Post Number: 8630
DumDude
Yes with F3 on remote, do not do a hard reboot.
Username: Satgrl
Dil Mei DarD a Jaga ...
Post Number: 1641
i had same problem on my pansat 2700 and i just put the latest keys in 0101 and it started working
KEY 00: 9D 89 C3 87 F3 77 3D 3A EB 07 A6 7C B0 CC FC 68<-----NEW
KEY 01: D9 2B 79 C7 DD C6 EE F4 09 E8 B4 96 B2 34 D0 60
Username: Plymouth
Post Number: 8641
satgrl
Viewsat doesn't have any problem with autoroll, so you don't need to put the keys on this box.
Username: Satgrl
Post Number: 1646
alright smarty pantsgeek
