PUFF_LZMA_208V2
Username: Nydas
Post Number: 14703
PUFF_LZMA_208V2 BIN
Alternative PUFF_LZMA link
Download and unzip into separate directory.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Instunctions for 208_V2
Fwank7_Jvvh-Team-PUFF_(Lzma)_V208_V2
After you finish loading this bin to your receiver you have to push 8282 (or Menu/Cas system/0000) on your remote to get to CAS SYSTEM. In there you will see " SET DEFAULT KEY " Go to it push OK on remote once then EXIT out and picture will come in right away. If you don't do that then you will get " SOBC " Nag until keys update. Do it and picture comes in right away.
Username: Nydas
Post Number: 14704
For original 2700 there is a new variation of the BL 208 BIN at
http://www.future-fta.info
Username: Tscon
Post Number: 123
"After you finish loading this bin to your receiver you have to push 8282 (or Menu/Cas system/0000) on your remote to get to CAS SYSTEM"
It's unclear where to push those 8282..
I go in that menu On Password type
0000 and they I'm in, where the heck on what screen I have to type 8282?
Anyways, I got SOBC nothing working.
Username: Tscon
Post Number: 125
Ok, I got it.. I did 8282 and set default key. STILL SOBC screen displaying only!
none of the channels on ECHO 3 working.
This bin
Fwank7_Jvvh-Team-PUFF_(Lzma)_V208_V2.BIN
DOESN'T WORK!!!
Should I reload the bin again or what?
Username: Desi_munda
Post Number: 223
good question
Username: Nydas
Post Number: 14716
I tested two converted receivers yesterday and they both worked immediately.
After loading the BIN, you start and as soon as you Exit out of EPG scan, do 8282 or do Menu/Cas/0000/set default keys.
Exit immediately and the system is on, if you have your previous channels scanned. Or scan again.
Post Number: 224
so we will get all the pakistani channel without going in advanced setting and changing the video pid etcc....??
can u just confirm that please?
Username: Redonorange
I put in the 208 and the channels came in right away. I did the set default keys and now get SOBC. Will the keys eventually come in? I have key roll on and the rest off.
Fixed! Turned on all the rolls and it came back in after a minute or two.
Username: Nydas
Post Number: 14720
Some of the Pakistani chanels have to be scanned manually. I have answered in
https://www.ecoustics.com/electronics/forum/home-video/560100.html
and explained the limitations.
Username: Nydas
Post Number: 14726
New LZMA_211 EXPECTED SOON.
Username: Tscon
Post Number: 130
"New LZMA_211 EXPECTED SOON"
Great cause really, when box get restarted
after loading 208v2, after P.U.F.F blink my last
channel came up right away, there is no way
to press 8282 before that, and If I
setting "Default Key" after channel already showed this doesn't help.. I have All Autoroll OFF except the KEY AUTOROLL (is ON of course).. K, will wait for 2011
bin, thanks Nalin, you still Dah! Man!!!
P.S
I'm thinking maybe this is again Overlap channel BS? I'll try reset the system reload bin, rescan, and then set default key? Ok, at least I'll try to rescan, just in case..
Username: Perycles2005
Post Number: 83
Hey VAsil...let us know how it goes when you do that...thanks.
