Viewsat Ultra dead t.t.cc
Username: Way2smart
Www.Desifta.com
Post Number: 1704
K so i did a factory default and then i loaded the current file and the receiver wont work now, i says t.t.c c
i loaded the main.pgm file it turns on and works fine but when i go to do the current file or factory file it goes back to the t.t.c c or something like this L.L.L.L
can someone please help me i loaded the file over 10 times now and still nothing tried both null and usb
Username: Way2smart
Www.Desifta.com
Post Number: 1706
nvm i got it... i loaded a cleaner file then opkey bin and then the latest bin and bam it worked
Username: Plymouth
Post Number: 8431
The $mart 1!
Are you sure that you load the good file and not the Ultra Lite?
Username: Way2smart
Www.Desifta.com
Post Number: 1712
it was the right file, but i got it fixed its all good now.... still need help with brown channels thou
