The $mart 1, I need your help
Username: Mrkhan
Post Number: 122
I have clone box 2500a pansat, which I upgraded to puff (LZMA) thanx alot for your help.
Username: Way2smart
Www.Desifta.com
Post Number: 1709
GO TO menu - installation - advance scan - select satellite press OK-
using volume on remote select the down frequency- 12326
go down to vid pid and enter 5666 - audio enter 5667 - pcr enter 5666
select TP scan and it should scan one channel -CH-A
Username: Way2smart
Www.Desifta.com
Post Number: 1710
All these channels will work only if you have 61.5!!!
AAGTV=TP12661(V) Vid(4898) Aud(4899) PCR(4898)UP!
ARY one world =12661(V) Vid(6434)Aud(6435) PCR(6434) UP!
PTV Global=12326(H) Vid(5666) Aud(5667) PCR(5666)UP!
QTV=12661(V) Vid(4130) Aud(4131) PCR(4130) UP!
Musik=12661(v)Vid(5922) Aud(5923) PCR(5922) UP!
GEO NEWS=12384(v) Vid(5154) Aud(5155) PCR(5154) UP!
ETC Punjabi=12355(H)Vid(7714) Aud(7715) PCR(7714) UP!
use these
