NALIN OR PLYMOUTH NEED HELP WITH MY PANSAT 2700A
Username: Crazycool
Post Number: 37
MY PANSAT 2700A IS NOT WORKING AT ALL WHEN I PLUG IT IN OR TURN IT ON NOTHING. NO B75 OR CHANNEL NUMBERS, CAN YOU PLEASE LET ME KNOW WHAT'S HAPPENING. THANKS
Username: Crazycool
Post Number: 38
NOW I SEE 8.8.8.8. AND CAN'T DOWNLOAD FACTORY BIN 124.
Username: Plymouth
Post Number: 8373
crazycool
I don't know this receiver but Nalin can help you.
Username: Crazycool
Post Number: 39
where is nalin when you need the help?
Username: Riconissan
Post Number: 544
crazycool,
If I know Nalin he is researching your problem and will address it shortly.
I do not know this box but when I Google "Pansat 8888" many pages load. there is a ot of information out there.
Username: Crazycool
Post Number: 40
I JUST DOWNLOADED FATORY BIN 124 BY TURNING ON THE RECEIVER AND DOWNLOADING THE BIN AT THE SAME TIME. SO I TURNED ON THE RECEIVER AND THE LOADER AT THE SAME TIME AND I GOT THE B75 BACK, AFTER THAT I DOWNLOADED BIN 209 AND NOW ALL I'M GETTING IS B75 AND IT KEEPS REBOOTING HOW DO I FIX THAT?
Username: Nydas
Post Number: 14691
Try Bin 124 followed by Bin 208, that's right 208 not 209. Let is come to "on" position. Then do user setup and antenna setup.
Switch off at back, abd after 40 seconds load the latest 209 BIN.
Go into antenna setup and scan.
Enjoy TV.
Username: Kermy
Crazycool, for future reference Nalin and Plymouth are one in the same
Post Number: 551
Yeah right.
Username: Plymouth
Post Number: 8399
""Crazycool, for future reference Nalin and Plymouth are one in the same""
Yeah 2 good guys always helpful for the Ecoustics members.
Username: Crazycool
Post Number: 41
NALIN I DID JUST LIKE YOU SUGGESTED DOWNLOADED FACTORY BIN 124 THEN BIN 208 AND NOW IT'S STUCK ON NUMBER 5 WHAT DO YOU THINK IS THE PROBLEM. THANKS IN ADVANCE
Username: Crazycool
Post Number: 42
OH BY THE WAY NALIN WHENEVER I DOWNLOAD THE FILES ALL I SEE IS NIGHTRIDER LIGHTS,AND WHEN IT FINISHES DOWNLOADING IT GETS STUCK ON NUMBER 5. WHAT DO YOU THINK ABOUT THAT, THE BOX IS A PANSAT 2700. I HOPE YOU CAN HELP ME WITH THIS PROBLEM. THANKS
Username: Kermy
Crazycool why are you shouting
Username: Nydas
Post Number: 14696
You seem to know what you are doing and are doing the right thing.
Use 27.02 loader throughout.
Try doing a reset (switch off and on) after 124 factory BIN.
Then do user setup and reset again, beofre loading the 207 0r 208 BIN.
The do reset and go on to 209 BIN.
Username: Crazycool
Post Number: 43
Nalin i did just like you suggested and now what it's doing is showing b75 and it keeps rebooting which to me is progress, so now how do i stop it from rebooting and back to normal, i'll be waiting for your feedback. thanks
Username: Nydas
Post Number: 14697
Try doing a system reset after loading 124.
Then do hard reset.
Then do user setup, antena setup and scan - it should scan although there won't be any TV.
Then do hard reset.
Now load the 207 or 208, do a reset.
The load the 209 and see if it will come through for a full scan again or show TV without a new scan.
You have an unusual problem.
Persistence will pay dividends.
