New cable
Username: Mike_m
Post Number: 51
i had recently bought a new computer with no serial port so i went and bought a usb serial cable for my pansat3500 sd i connected the usb end in my computer then i connected the serial to my 3500.when i try to download the bin. i get a message saying cant open serial port. then it says last error the system cannot find the file specified.please any help would be a blessing
Username: Dimwitt
Post Number: 1197
You have to use both cables usb/serial and the null cable.
Maybe your new computer has a sd card slot and you can use that feature on the 3500.
or something like this
SD Card Reader Via USB- SD to USB Card Reader
www.spyville.com/sd-card-reader.html
Using sd card would eliminate disconnecting receiver and taking it to comp.
Username: Nydas
Post Number: 14682
USB to serial convertors are notorious for problems and for slowness.
Buy only the type with its own installation CD.
Do not allow windows XP to install it.
Manually install using CD
Select COM1, or COM2, or COM3 or COM 4 port.
Use device manager in your computer to check and select the right port.
