VS2000 Update - anyone try this yet?
Username: Razz
I tried bin - I just get AR processing / loaded factory first, rebooted, etc.. etc..
____________________________________
DBPSW-090227P
* Versions
- Release Date : 2009.02.27
- Main software : DBPSW-090227P
- Bootloader : 0.0D
* Change
( Main software upgrade )
- AR Update
Username: Tigger_woods
I AM BACK, MATCH PLAY FEB 25TH
Post Number: 983
Its no good, wait for new file.
Username: Plymouth
Post Number: 7817
raz zor
Check your setting in antenna setup, after a scan the setting can come with default setting.
Post Number: 984
VS Plat bin has been pulled from most sites. We are waiting on one.
Post Number: 985
The file was bad. Load the Cleaner file to fix it. Then just wait for a new file.
C/P from Cyphris
Quote:
The VS Coders are aware of the - - - - issue and a new file is being made. It will be released when ready.
Username: Razz
Plymoth - Ant settings are good - I also use a Pansat reciever and it worked fine up to yesterday on same LNB's (settings matched the previous setup and were checked)I get 92% signal 98% quality on both
Tiger - Im new with VS what is a cleaner file? a factory bin?
Username: Riconissan
Post Number: 199
DBPSW-090227P Working since 12:30 eastern
I am not experiencing any autoroll or freezing.
J
Post Number: 200
All 3 of my VS platinum are up with this bin downloaded from ftahq at 11:56 eastern.
DBPSW-090227P
Username: Razz
Thanks Rico ill try to load cleaner file as suggested by Tiger - I found this file : - Is this the one Tiger??
DBPSW-Cleaner-P
* Versions
- Release Date : 2008.12.09
Username: Laguna
Post Number: 24
Loaded xtrm bin and says "no CH" on receiver and it shows no tv channels. Is that what everyone else is experiencing or is mine dead?
Username: Plymouth
Post Number: 7823
Vicente
I give a answer on this thread:
https://www.ecoustics.com/electronics/forum/home-video/554597.html
Username: Razz
Well - it all seems to be working now, it took AR about 20min to roll, guess i was impatient earlier,(use to pansats) for now all is working
Thanks for everyones help!!!!
Post Number: 204
Thanks to Plymouth PhD
Username: Plymouth
Post Number: 7830
LOL
Username: Laguna
Post Number: 26
Plymouth,
which factory bin and satellite info do I load from the viewsat usa website (i have viewsat extreme)? I know the loading the latest bin part. I went on that website and don't see anything pertinent. Thanks.
Post Number: 208
Rico Suave
Post Number: 207
Posted on Friday, February 27, 2009 - 08:44 pm: Edit Post
Viewsatusa. com
Support
Firmware
VS Xtreme Factory Bin File - V0279
Sat info
General Satellite Info File (Ultra )
Sat Info is the same for Xtreme
Username: Razz
Vicente - Its under the firmware section follow this link
http://viewsatusa.com/support_firmware.html
