2700 not loading
Username: Charjam
Post Number: 373
i can't get the 209 to load hit download and it sits at 0 % tried two different loaders tried letting it come on tried hitting it as soon as i saw the light the download comes on but doesn't do anything stays at 0 % i am using loader 2702 is there another loader ??? thanks
Username: Charjam
Post Number: 374
Hey guys no one has any ideas i have used 3 diff loaders and 3 diff files all my loaders says download not write where can i get one that says write maybe that would help
Username: Dimwitt
Post Number: 1132
The 2700 uses loader 27.02, if you are sure you are using the correct 'null cable' and it sits at 0% - Try reboot computer & 2700 and start over.
possible SNAFU
Username: Charjam
Post Number: 375
I finally got it , this is what i did i changed the usb port and changed the com port i don't know if that had anything to with it or i just got lucky took 3 hrs.
