Silver Member Username: FrobiPost Number: 267 Registered: Aug-06 | How do I configure COM port on Toshibs laptop to load files. It says no COM port where as there is a serial socket for the serial cable. | |
Platinum Member Username: NydasPost Number: 14511 Registered: Jun-06 | Laptops usually have a USB port. An old type of serial port is usually a 9 pin male at the back of the comuter. You need to buy a USB to serial converter. Make sure you buy one with a installation CD. These converters are notorious for connection problems and poor speed. You must go into your Device Drivers and make sure your connection is configured as COM 1 |
Silver Member Username: RiconissanPost Number: 151 Registered: Feb-09 | what is your model Toshiba laptop? | |
Silver Member Username: FrobiPost Number: 268 Registered: Aug-06 | You are right, Nalin. My mistake. I have USB adaptor for the the cable but the loader for VS extreme is asking for a port. | |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2533 Registered: Dec-06 | here is a small utility to check what com ports are open
Silver Member Username: FrobiPost Number: 269 Registered: Aug-06 | Its Toshiba A200-08J | |
Silver Member Username: RiconissanPost Number: 152 Registered: Feb-09 | Doreen utility is cool. I didn't have it. Thanks | |
Gold Member Username: PlymouthCanada Post Number: 7766 Registered: Jan-08 | Hi Riconissan! How are you today? |
Silver Member Username: RiconissanPost Number: 153 Registered: Feb-09 | Good Brother, It seems like the forum is cleaned up. Back to normal. J |
Gold Member Username: PlymouthCanada Post Number: 7768 Registered: Jan-08 | I hope the peace will be last. |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2535 Registered: Dec-06 | your most welcome Rico | |
Platinum Member Username: NydasPost Number: 14512 Registered: Jun-06 | Riconissan: "It seems like the forum is cleaned up. Back to normal." Don't be complascent. The impersonator is/was back with the name Riconissam So take care. |
Silver Member Username: RiconissanPost Number: 155 Registered: Feb-09 | Got it! Thanks |
Silver Member Username: King_of_satsPost Number: 934 Registered: Jan-08 | ||
Silver Member Username: King_of_satsPost Number: 935 Registered: Jan-08 | 3 more years past.. and the LOSER LK still here and crying day after day.. same chit differnet name ... |
Silver Member Username: King_of_ratsPost Number: 329 Registered: Jun-08 | . |
Gold Member Username: GregrafPost Number: 2265 Registered: Dec-07 | ||
Silver Member Username: King_of_satsPost Number: 936 Registered: Jan-08 | |
Gold Member Username: GregrafPost Number: 2269 Registered: Dec-07 | Thats one ugly dude Nimda | |
Silver Member Username: RiconissanPost Number: 173 Registered: Feb-09 | Now that is funny! | |
Silver Member Username: King_of_satsPost Number: 937 Registered: Jan-08 | |
