i am looking to get a pansat 9200 before n3 is launched. is this receiver expected to have any problems with the n3 switch? second i would like to know if a regular dish 1000 will work as the antenna for it and if a dp lnb and a regular single lnb will work if not what kind do i need thank u in advance
1. It will have the same problem as the rest of the FTA receivers when the N3 switch becomes available. At present there is NO N3 SOLUTION for any receiver except Nfusion on BEV only.
2.Decision for LNBs and dish is related to what you want to watch. In particular for the Eastern Arc there is a special Dish/LNB combination. For most there is 1000, and for getting 118.7, there is 1000+ dish and matching LNBs.
