CW700
Username: Ennio
Post Number: 57
How can you tell if is real or clone if you buy one?
Username: Plymouth
Post Number: 7308
ennio
Look at captiveworks.com and check for dealer list.
Username: Nydas
Post Number: 14274
Buy from an authorised dealer.
If you end up with a clone, however, there is a solution.
CW700 Code Verification Crack (working on Original or Clone)
If your serial is not working or not have the serial Use these Serial Numbers.
071112190 -> 071112199
071112200 -> 071112209
071112210 -> 071112219
071112220 -> 07111230
