Hey which good box to buy from Pansat model that also has the bin files updated with release? Hey I updated my box to Puff LZMA from its original Puff, is that good?
In th ecurrent situation, i would not recommend spending on a new receiver. If you must, buy a 250SM. None of the Pansats or other receivers come with "BIN file updated with release".
I would go with Sonicview hands down. Sonicview has the best in support. A plan in place for Nag 3. The base unit the Sonicview 360 Premier, has pvr front loading usb, and reasonable cost. Coome Win one at FTALife.com free to join, and you could get a free receiver.
