Bronze Member Username: Xxxx1234Post Number: 33 Registered: Sep-06 | http://www.google.com/search?hl=en&q=jvvh5897_puff_201g&aq=f&oq= |
Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 841 Registered: Mar-07 | xxx1234 is a new name. Is this guy known to anybody here? I don't want to go for a file from a guy nobody knows. |
Silver Member Username: JuanchoCANADA Xx Post Number: 275 Registered: Jun-08 | abby, I have the bin, the bin is the same that I have, It works, load the bin as before,after do a factory setting and scan your sats. |
Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 842 Registered: Mar-07 | Thanks Juan. |
Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 843 Registered: Mar-07 | Works just great on Echo8 and Echo3 but on Echo7 I get a black screen on every channel. Tried my old channel list and tries rescanning but still nothing on Echo7 works by any method. Any Ideas? |
Platinum Member Username: NydasPost Number: 13587 Registered: Jun-06 | Jvvh5897_puff_201g file: The e and f versions were very experimental and buggy. the g version has fewer bugs - Having said that it still has more bugs than I want to cope with. |
Silver Member Username: JuanchoCANADA Xx Post Number: 281 Registered: Jun-08 | Did you have the pansat2700a for compare?jvvh has improved this bin a lot. don't use ch.list. just try rescan. why no start the scan with echo7, after echo110,I only have echo7. I will try both sats. |
Silver Member Username: JuanchoCANADA Xx Post Number: 282 Registered: Jun-08 | Did you have the pansat2700a for compare?jvvh has improved this bin a lot. don't use ch.list. just try rescan. why no start the scan with echo7, after echo110,I only have echo7. I will try both sats. |
Platinum Member Username: NydasPost Number: 13590 Registered: Jun-06 | Actually Juan, I am having health problems and will not be testing or posting for 5-10 days |
Silver Member Username: JuanchoCANADA Xx Post Number: 288 Registered: Jun-08 | Nalin Nyda Platinum Member Username: Nydas Post Number: 13590 Registered How comes so many post |
Silver Member Username: PsychmonsterRhodium Member aint nuthin... Post Number: 997 Registered: Jul-06 | Bummer NN...hope its not too serious..we all jive and jab each other but nobody except a few can be happy when someones health fails... what you need is a good rest |
Silver Member Username: Jagr1234Post Number: 193 Registered: Nov-07 | jvvh 201f 1. disconnect sat input 2. flash 201g as normal 3. reconnect input before loader states BURN it will retain current channel list and no need to rescan FYI |
Gold Member Username: RunnerguyPluto Post Number: 1700 Registered: Sep-06 | To Nalin: |
Silver Member Username: Snw7619Bahamas Post Number: 246 Registered: Oct-06 | wher can i get v210G?????? |
Silver Member Username: MrgregOnt. Canada Post Number: 198 Registered: Dec-07 | Here it is and it is 201g not 210g |
Bronze Member Username: Popol_vuhPost Number: 89 Registered: Jan-08 | Nalin, sorry to hear about your health problems. Keep your spirits up and get well, no good deed goes unrewarded. |
Bronze Member Username: DawoodPost Number: 11 Registered: Feb-08 | Nalin, Get will soon and take care of yourself. Come back as soon as you are OK. |
Silver Member Username: LetmeonPost Number: 249 Registered: Mar-06 | Have 201g running on Pantec Ultra (PUFFED), running fine. Had one freeze last night, otherwise runs OK. No rolling PUFF display when power is disconnected. |
Bronze Member Username: Popol_vuhPost Number: 91 Registered: Jan-08 | Did you lose the scans after shutting it down overnight? I'm talking doing a soft OFF for the night... TIA for your response... |
Bronze Member Username: KaanwalWindsor, Ont Canada Post Number: 23 Registered: Sep-08 | Nalin get well soon.} |
