after loading the v201 from lathario, I am missing half of my channels on 1*18, I am now running Tronics v201 and it's still the same. anyone having the same problem?
Thanks Nalin for replying, I do have all the settings right, all these happened after the Lathario BIN, can't find TP 11715 etc......this had happened before last time when there was a bad BIN a while back.
DO NOT use Lothario BIN. Fwank7 or UKR BIN is sort of OK with some problems mainly at the time of installing. You have switch off as soon as P appears, then after connecting and turning it on you do not turn off!
jvvh 201e or 201f are both experimental and should NOT be used till the author releases them to the public.
Tronic PUFF_201 is good - it solves the PUFF rolling problem of Fwank7 and UKR, but has some glitch causing rescans.
