Do factory reset, install factory BIN 124 using loader 27.02 and then install the full emu V201 BIN. You will have to do setup and rescan. Avoid using Channel master for loading channel list.
i did what u said nalin, a little bit. i factory defaulted, but i scanned before i put the bins in. will that affect anything, also when can i start using channel master? someone told me after your done loading a bin u have to write to stb.
The new 201 BIN is not fully compatible with memory locations of scanned channels. You may end up having to scan and rescan. 1. Factory 124 2. Latest BIN. 3. User setup 4. Antenna setup. 5. Scan one sat and REMOVE unwanted channels. 6. Do same with another Sat. 7. Try and pretend everything is back to normal!
Albino Midget Few receiver functions are insert in Provider Keys, deleting providers erase bad data in receiver and many times that recover many problem with no signal, autoroll and Tp lost.
il try. i found a Cool sat FTA Satellite Receiver 6000 Premium with Universal Remote Control Almost New. is it a good reciever, should i buy it? is it the one with the usb port?
