New ECM 6th December - DN
Username: Nydas
Post Number: 13418
DN went down on most receivers today at about 5 pm.
BEV has been down for 2-3 weeks.
Username: Gregraf
Post Number: 1711
Username: Jays247
Post Number: 7
Which receivers work?
Username: Nydas
Post Number: 13422
Nfusion Nova - said tobe working.
Almost all the other brand names are down.
Username: Justforhahas
Post Number: 1484
DN has an ECM in progress since 5PM EST...All receivers using DN channels are down, except Nfusion on IKS...No older files reported to work....NEW FILES ARE NEEDED, NOT KEYS! .....Be patient and wait for new files from www.ftabins.net ..files usually takes a few hours so don't expect anything until at least 10 PM EST or later as a guesstimate...GC is still up , except for their Nagra 3 channels...Bev is dead too except on Nfusion IKS...The fight is stream live on www.justin.tv/hufhjd
Username: Sman154
Thanks for the repeated SPAMfest on all threads.
Username: Gregraf
Post Number: 1714
Its better than what you have to say sman or swoman
Username: Sman154
Ouch, such a cavalier you are SIR Raf, please enlighten me on your meaningful contributions other than gender assumptions
Username: Nydas
Post Number: 13431
Status of 12/16/2008 ECM
New filese released.
Please Note: All fixed are only for DN only!
Nfusion - did not go down at all.
ATMEGA
BUZZ
CAPTAIN
CAPTIVEWORKS
C00LSAT 8000. 8100, 4K, 5K, 6K
DREAMBOX
EXTREMEVIEW
HOMESAT
ICON
KBOX K1 PLUS
PANSAT (3500 ONLY)
SATOPIA
SKYVIEW
SPACESTAR/SONYSAT
SONICVIEW
VIEWSAT
Username: Nydas
Post Number: 13432
Pansat 250SM, Pansat 2800 and Pansat 9000/9200 HD are also up with new files
Username: Slo_hand2
Post Number: 495
thanks for the update I'm waiting on cnx trio and pansat 2700a
Username: Rveeraga
it appears CS 6100 file still not available?
Username: Nydas
Post Number: 13438
rveeraga: It seems you are right.
Username: Slo_hand2
Post Number: 499
Cnx trio/duo/mini/nano files are up as well!
Username: Nydas
Post Number: 13462
Pansat 2700A/E receivers:
The new 2700A BIN is out and
IT IS A FULL EMU VERSION 201
[link removed]
Pansat 2500/FLU receivers:
People should NOT use the tronics converter, but wait for the conversion PUFF BINs
