Pantec 2500
I have Pantec 2500 (clone). it was used 2 yrs before. how can i make it work again? I heard that i have to convert it to 2700 and then PUFF..
can anyone let me know how can i make it function again?
from where can i find latest program (bin files)?
Post Number: 11896
Follow the instructions in the full-kit. Most people are going for the PUFF installation.
MAKE SURE that you load the 294T on your receiver before doing any conversion.
FLU/2500 Conversion to 2700 workalike.
Full kits for Latest conversion BINs and other files - also for Revert to 2500
[link removed]
[link removed]
Please read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Hi Nalin, Thanks for prompt reply. I am trying to download files from PUFF link but it says "This user is out of bandwidth" and does not allow me to download anything.
I am really not pro with this, can you please send me step by step info. with required files to my personal id.
Quebec city, Quebec Canada
Post Number: 4282
Arnold123
Now it is better
Thanks Plymouth.. but i am really stuck here.. i am badly looking for step by step procedure with reliable files and it become more difficult when one is new. i hope you understand.
Post Number: 4283
Arnold123
Go to dsstester com and choose pansat all files are there, but i know nothing on Puff.
Sorry
Post Number: 12029
One of these links should work
[link removed]
[link removed]
Download and unzip into separate directory.
Post Number: 38
Easy to do .. just follow the instructions in nalyn links...
Did it for 2 boxesAND THEY WORK FINE.
Username: Arnold123
Thanks Nalin,You are really helpful. i have downloaded files. I will read everything first. I believe, i have to install either PUFF or B75 right?
you also advised to download 294T file first before doing anything. from where can i find 294T?
Username: Nydas
Post Number: 12093
294T file is in
boot60 area sub-directory of full_kit in PUFF section
Revert to 2500 sub-directory of b75 section
Revert to 2500 is also posted as separate directory.
Username: Arnold123
after laoding 294T on my 2500 pantec clone.
should i convert it first to b75? or i should go directly to PUFF link.
Can you please give me BIN file names?
e.g.
1. X-85BL_070812_294T_Api (I load this file first)
2. Receiver is already 2500 so i might now need to covert it to 2700 (B75)
if yes(which file i should use)?
if No (which PUFF file i should load)?
Username: Nydas
Post Number: 12102
If you want to have b75 boot (minimal support) use b75 section. PUFF is supported by more people. If you want to install PUFF boot use PUFF section.
Download the appropriate full section and unzip into a separate directory.
Follow the instructions in the unzipped directory.
Username: Arnold123
ok..
2. i can directly load CS_253T_PUFF_BOOT_serial_lightning (640 kb)
to get the PUFF?
Username: Nydas
Post Number: 12103
READ THE INSTRUCTIONS
AND FOLLOW THEM CLOSELY.
EVERYTHING IS THERE.
