Bronze Member Post Number: 68 Registered: Dec-07 | Hi everyone..heres the problem...My sv premier wont boot up. Turns on but stays on the menu screen. Just a blue screen nothing more. I tried shutting it off from the back switch but it still wont work. The front panel just shows the word "Main". Please help. Thanks |
Bronze Member CANADA Xx Post Number: 79 Registered: Jun-08 | Turn Off STB Format Pendrive(USB) Last bin Put pendrive in USB port, Press and hold front power button. Now turn on stb with back sw. select file and blahblah... |
Bronze Member Post Number: 69 Registered: Dec-07 | ill give that a try thanks |
Bronze Member Post Number: 70 Registered: Dec-07 | it didnt work. I still get the blue screen and it still wont let me access the menu. anything else i can try? |
Gold Member Quebec city, Quebec Canada Post Number: 4108 Registered: Jan-08 | David You must use cable, the loader and load the factory bin then load latest bin Here is the loader and factory file: http://www.sonicviewusa.com/support.html |
Bronze Member Post Number: 71 Registered: Dec-07 | thanks plymouth. ill give this a try. ill post my results. thanks again |
Bronze Member Post Number: 72 Registered: Dec-07 | ok i tried the loader ver 1.1 but the loader wont detect the box. i tried loader v2.01 and still no detection. Box turns on but it only shows MAIN on the front panel. anything else i can try..thanks |
Gold Member Quebec city, Quebec Canada Post Number: 4128 Registered: Jan-08 | David Turn Off STB Press and hold front power button. Now turn on stb with back sw. and release front power button now load the file with the loader |
Bronze Member Post Number: 73 Registered: Dec-07 | thats a no go..could there be something messed up inside the box??maybe a capacitor or something. |
Gold Member Quebec city, Quebec Canada Post Number: 4144 Registered: Jan-08 | David Unplug Power Cord for the night and check if it work tomorrow. I dont think a capacitor is blowed. The box does not boot. How it happened, on a new bin file or itself for nothing? |
Bronze Member Post Number: 74 Registered: Dec-07 | well it was running before the latest fix. i went to load it as usual via front usb port. the box didnt want to take the usb front or back so i just turned off. when i turned back on a few minutes later all i received was the blue screen. no words on the screen. cant even access the menu. |
Gold Member Quebec city, Quebec Canada Post Number: 4145 Registered: Jan-08 | Why all Guys who say Sonivicview is the best receiver are not here for help you? Dont take it personal David, but i alway recommand Viewsat and Captiveworks for best support and a bundle of clowns try to say it is Soniview, now all these clowns dont help you. Dont be worry with it, i go continued to help you. |
Gold Member Quebec city, Quebec Canada Post Number: 4146 Registered: Jan-08 | OK Are you sure the Pc can communicated with the receiver? Do you have a error message on Pc screen? You need to choose the port 1 on tool menu in Loader. What is display when you do it? """"Press and hold front power button. Now turn on stb with back sw. and release front power button"""" Give me a clear answer on all these quetions. |
Bronze Member Post Number: 75 Registered: Dec-07 | THANKS PLYMOUTH...ok the loader wont detect the box. There is no error message that pops up. PORT 1 is the only option on the tool menu. PC port and the cable are fine. I used the same port and cable to put the latest file on my pansat 2700 few minutes ago. The only display i get doing the power button thing is "MAIN" |
Bronze Member Post Number: 76 Registered: Dec-07 | seems like the pc is not communicating with the receiver. i get this from the info button on the loader MODEL BOOT VER MAIN VER all come up blank |
Gold Member Quebec city, Quebec Canada Post Number: 4147 Registered: Jan-08 | David Unhook the LNB cable and power "ON" and check what is diplayed. |
Bronze Member Wenonah, New Jersey USA Post Number: 17 Registered: Jan-08 | david, Also make sure you are using the correct cable when loading from PC. There are different cables for different stbs. Once you are able to load from PC it should be OK. Hope this helps. |
Bronze Member Post Number: 78 Registered: Dec-07 | ONLY THE BACKGROUND PICTURE SHOWS. ON MY BOX IS A BLUE SCREEN WITH SOME STARS ON IT. THATS ALL THAT SHOW. DOESNT SAY ANYTHING ON THE SCREEN. REMOTE DONT RESPOND. |
Gold Member Quebec city, Quebec Canada Post Number: 4149 Registered: Jan-08 | Try to load this bin file with the loader and try directly in USB port too |
Bronze Member Post Number: 79 Registered: Dec-07 | no good. well im going to stop for today. if you get any other ideas please let me know. Thanks again. you been a great help |
Gold Member Quebec city, Quebec Canada Post Number: 4150 Registered: Jan-08 | Sorry i try to found a solution for you tommorow. Gone to sleep now good night |
Bronze Member Post Number: 80 Registered: Dec-07 | WELL I SPENT A GOOD AMOUNT OF TIME SEARCHING THIS MORNING FOR OTHER WAYS AND CAME ACROSS THIS..... How To: Force Loading SV-360 Premier Quote: - turn the the premier off completely - format flash drive - copy latest fix to flash drive - insert flash drive into premier usb port - press and hold ok button(locate on the front panel) then turn the premier on using the rear power switch, select file and let it load. Worked like a charm. used the factory file and its good!!. THANKS PLYMOUTH FOR ALL YOUR SUPPORT. THANKS AGAIN |
Gold Member Quebec city, Quebec Canada Post Number: 4151 Registered: Jan-08 | Good news David Enjoy |
