Bronze Member Post Number: 36 Registered: Nov-06
Posted on I have a Fortec Classic NA. Is there a way I can make that thing work like convert it to Pansat 2500 etc. or is it garbage now? |
Silver Member Post Number: 343 Registered: Jul-08
Posted on its a door stopper now...no conversion or files |
Platinum Member Post Number: 11820 Registered: Jun-06
Posted on Use it as a paperweight if you have a lot on your desk |
Silver Member Post Number: 351 Registered: Jul-08
Posted on Shove it in nalin's mouth and shut her up..she just posts wrongful bogus info or repeats what's already been posted by another. |
Platinum Member Post Number: 11822 Registered: Jun-06
Posted on justforhaha's: Shut up you stree walker from Key largo. |
Silver Member Palatine,
IL
Post Number: 163 Registered: Apr-08
Posted on What's a stree? Does it get GC? |
Platinum Member Post Number: 11828 Registered: Jun-06
Posted on It gets CG. When you wear your shoes on the correct foot (an impossibility for you) then it gets GC. |
IL
Post Number: 165 Registered: Apr-08
Posted on What is cg? do you mean center of gravity? Your stupid is showing.................better zip up. |
Gold Member Post Number: 1260 Registered: Dec-07
Posted on |
