Post Number: 80 Registered: Nov-06
Tuesday, September 23, 2008 - 14:58 GMT My pansat 2700a is giving me a hard time. B75 flashes from left to right and is moving constantly. Pls help thanks
Post Number: 73 Registered: Jul-08
Tuesday, September 23, 2008 - 17:13 GMT I would try to convert it to PUFF which is more supported. PUFF:http://www.box.net/shared/xu4t9fmg4w B75:http://www.box.net/shared/yzbm7ayw44
Post Number: 11777 Registered: Jun-06
Tuesday, September 23, 2008 - 18:38 GMT PUFF Diver: You should NOT post on subject you do not know about. The genuine Pansat 2700A DOES NOT USE PUFF bins. Use the BL bin from http://www.future-fta.info The name of the file is: X-87BL_080922_B75_290_api.zip Unzip it to extract the BIN file and load it using 27.02 Loader.
Post Number: 82 Registered: Nov-06
Wednesday, September 24, 2008 - 14:00 GMT Thanks for help Nalin. But once again it was working all good until day before yester hit and i factory reset and it started flashing left to right. Why is it flashing. So all i need is to download new file?
FL
Post Number: 2283 Registered: Jan-07
Wednesday, September 24, 2008 - 14:10 GMT ozjatt nalin is right.try loading the factory bin then the current bin.remeber to make sure you unzip the file.good luck
Post Number: 11809 Registered: Jun-06
Wednesday, September 24, 2008 - 14:39 GMT [link removed] Pansat 2700 factory file v124 (diseqc1.1 upgrade) Pansat 2700 factory file v124 (diseqc1.1 upgrade) Pansat 2700A_080617_B75_124_ap.zip *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*- [link removed] New 2700 Loader (and factory file #1.20 ) New 2700 Loader (and factory file #1.20 ) This file has the loader and the factory file (bin 1.20). You will need this loader to do the boot fix upgrade. Attached Files 2700A loader.zip *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*- [link removed] X-87BL_080922_B75_290_api. X-87BL_080922_B75_290_api Dn ecm fixed.. Attached Files X-87BL_080922_B75_290_api.zip
