Bronze Member Username: ToneyAntigua Post Number: 61 Registered: Dec-05 | Hello Everyone, Can someone explain to me why dishuser.org have a lot more channels under Dish Channel Chart on Echostar 3 (61.5) than lyngsat? Can someone explain to me how can I see what type of encryption (N2 or N3) Dish on Demand PPV Channels and other channels uses on Echostar 3 on the website dishuser.org? Thanks in advance for your response(s). toney. |
Platinum Member Username: NydasPost Number: 11526 Registered: Jun-06 | Toney: From the location you are iN, if you do a Blind scan for the sat you are pointing to, you will get the maximum that is available to YOU AT YOUR LOCATION. |
Silver Member Username: MuchoPost Number: 620 Registered: Dec-07 | Andre Toney Can someone explain to me why dishuser.org have a lot more channels under Dish Channel Chart on Echostar 3 (61.5) than lyngsat? I have ask the same question before didn't get an answer. One of the reason could be that at http://dishuser.org/61-5list.php they list EchoStar and Rainbow as one. Also from Channel 4100 to 5961 are all listed as HD and about 16 are Test Channels. |
Bronze Member Username: ToneyAntigua Post Number: 62 Registered: Dec-05 | Thanks Nalin Nyda and White Hawk for your responses. I really appreciate them, but do you know if the PPV on Demand Channels on Echostar 3 have Nagravision 3 Encryption on them besides they are MPEG 4? Thanks in advnce for your response. toney. |
Platinum Member Username: NydasPost Number: 11530 Registered: Jun-06 | At present a lot of channels are being broadcast on both Nagra 2 and Nagra 3. There are not too many PPVs on Echo 3. Please be specific as to which TP frequency, you are looking at. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3377 Registered: Oct-06 | This is similar to Sat-man's situation from Arkensas Yo can change the frequency pitch to get other channels but will lose others on same TP To get that Yo do TP scan while changing freq by trial and error White Hole Don't try this at home ![]() Yor only 13 years old ![]() This is adult swim now ![]() |
Gold Member Username: Oleg1474Florida Usa Post Number: 1100 Registered: Aug-06 | i need loader for Pansat 3500SD |
Bronze Member Username: ToneyAntigua Post Number: 63 Registered: Dec-05 | Thanks Gentlemen for your responses, but this is my situation. I am living in the southern part of the Caribbean and where I am living I can only recieve Echostar 3 (61.5) Signals. Once upon a time, I used to pickup Echostar 8/10 (110) but my neighbour built a garage in front of my dish which blocked me out from recieving Echostar 8/10 signals. The only choiced I had was to put my dish on Echostar 3. The point is, I miss my Pay Per View Channels on Echostar 8/10 and I would like to get them back. I saw in the Echostar 3 Satellite chart on the dishuser.org website that there are Pay Per View Channels (502 - 538). I am planning to buy a SonicView 8000 HD along with the A-1 Module, but I am not sure if the Encryption on the Pay Per View Channel is Nagravision 2 or Nagravision 3. Can some tell me the Encryption on these channels at present? Thanks in advance for your response(s). toney. |
