Problems in Black Tyger BINs
Username: Nydas
Post Number: 11114
I have tested Black Tyger PUFF_276 and LZMA_276 BINs and regret to say that there are some problems.
I am therefore advising everybody to use other BINs.
I have not tested the Black Tyger b75_276 BIN.
In the deffective two BINs, all vertical TPs 12543 and above are not coming through.
The result is that you will not get AAG, B4U, ZGUJ, ZTV, ZCINE, PTV, Melody,etc on Echo 3.
I have tested the Tronics BIN b75_276 and it is working fine including all the vertical TPS.
Username: Nydas
Post Number: 11122
The author of Black Tyger BINs has confirmed defective BINs, has corrected the problem and is suggesting version 2 of these BINs.
Username: Nydas
Post Number: 11141
If you are still loking for b75 or PUFF BINs or want to convert ---
Apparently box.net has removed public links and now allow urls.
'PUFF links' for full kit 276 and files
http://www.savefile.com/projects/808662067
'b75' Links for full kit 276 and files '" also for 'Revert to 2500'
http://www.savefile.com/projects/808662079
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Username: Vanticano
Post Number: 14
puff 276 has problem.
Username: Lroy
Post Number: 406
There is no problem with puff 276 bin, the problem is with the first Black Tyger puff 276 bin...
Username: Nydas
Post Number: 11145
I have tested the tronics and the fwank7 276 PUFF BINs and there are no problems
Username: Nydas
Post Number: 11154
Bump
