Zmodem.ll
Username: Crank606
Post Number: 39
guys i just recently got a laptop and wanted to start using it for the satellite when i try 2 download vs loader2 it says missing zmodem.ll any one can help would be appreciated thanks in advanced
Username: Bernardmi
Post Number: 168
Do you have a serial port on your laptop ?
What brand/make of laptop ?
Username: Crank606
Post Number: 40
compaq... windows vista and its zmodem32.ll
Username: Abe125
Cali
Post Number: 25
are you intalling the software???
Username: Bernardmi
Post Number: 170
Do a Google search on zmodem32.dll. Lots of stuff pertaining to Loader2 not working correctly unless the file is located in the same directory as Loader2.
Why are you using Loader2 anyway ? Just install Loader1 and you won't get the message !!!
Username: Crank606
Post Number: 42
well 2 let u know i just d/l loader1 and its working
