Viewsat Pro completely frozen!
Username: Thadragun
Kingston, Ontario
Post Number: 59
I'm not sure what the heck to do. My viewsat pro is completely frozen! I don't mean the satellites are down. Which they are but I mean none of the buttons will work on the remote or on the receiver.
It is stuck on channel 00178 and even switching off the receiver from the back doesnt help. It will turn off... it says boot when it turns back on and it goes back to 178 and still nothing works. I cant change the channel, I cant get info, or the guide, I cant go to the pvr files... nothing.
What do I do?!?
Username: Asharfi
Post Number: 2019
Please try turning OFF your receiver and leave it aside for a minute or 2. Then, turn ON and re-load the latest bin.
Username: Nydas
Post Number: 11107
If AV's suggestion des not work, you will have to load the factory BIN and then load the latest.
Username: Tinfish
Post Number: 149
hi has this happened to anyone else? does the method to reset work? what does one do if the receiver doesnt respond to anything?
Username: Rampeij
Post Number: 30
Turn off the VS Pro from the switch in the back, unscrew the coaxial cable from the satellite, and turn on the box.
Do not put the cable back in. Load the latest bin.
After the reboot, turn off the switch, screw the coaxial cable back in and turn on the box again.
Username: Addtemp
Post Number: 166
Well new File is already out but you still have to UnPlug the Satellite cable from the back reboot update the new file and then youa re all set
Username: Wabash
Santo DomingoDominican Re...
Post Number: 83
What worked for me was switching it off in the back, then switching it back on with the dish cable off or quickly changing to a free-signal channel like channel 100. I'm limited to watching the six mini-feeds there or the old recordings on my PVR drive. Hopefully we'll get a quick solution
Username: Wabash
Post Number: 85
BTW, where is the new file available, Aamir?
Username: Halo
Toronto, Ontario Canada
Post Number: 562
new files available at www.dishkeys.co.nr!
Username: Doreenakadj
Ontario Canada
Post Number: 1712
tin fish...I gave this advice to another guy with "frozen" receiver for VS pro. Use the VSPROLoader(serial port loader) then newest file. He said it worked for him. Give it a try
Ontario Canada
Post Number: 1713
also use the factory bin first VSPRO Factory Bin File - V106
Username: Thadragun
Kingston, Ontario
Post Number: 60
Thx. All I had to do was unplug the coax satellite cable and power off then on again.
What would make it do that?
Username: Tinfish
Post Number: 150
Thank you all.
