8PSK board for HD Receiver
Username: Kiranap
Post Number: 17
I am planning to buy HD reveicer, either Sonicview or Viewsat ... Have a question-
Do I need to worry about 8psk Board? What is it?
Thanks ...
Username: Salam
Post Number: 95
It is a must have. Get one that has already 8psk board installed. It is on the net all over.
One question I have is that do you have to change your dish or LNB once you have your HD receiver set up.
Username: Salam
Post Number: 96
correction, must have if you want DN stuff
Username: Kiranap
Post Number: 18
How abour BEV? ... BEV does not need it???
Username: Nydas
Post Number: 11045
BEV HD is a different (slightly inferior) HD and is available on most HD receivers without an additional board.
For DN HD you need a 8SPK board or add-on device - about $150 more.
Username: Laxey34
Miami, FL United States
Post Number: 35
Can you see HD singnal on a Transponder with a Pansat 2700A Receiver?
Username: Tapeman
New York City in-HD, NY
Post Number: 2972
B#V is a 720p HD MPEG-2 (4PSK encoding modulation)
D#N is a true 1080i MPEG-4 (8PSK encoding modulation)
Any SD MPEG-2 receiver can see and load HD channels but won't be able to output 720p on a 480 video port resolution so an HD receiver is required
I personally think all HD FTA receivers are way over priced and they are maximum 720p output none of them are true 1080i output they are all inferior receivers that's the real rip off
But if yor craving HD I would go with Sonic View or Viewsat
I evaluated a regular SD VisionSat PVR $125 on a Panasonic 720p 42" Unbelievable picture and color depth
It blows away viewsat crappy video
And can record to an external USB Hard Drive like a TIVO
Username: Kiranap
Post Number: 20
Thank you guys .......
Username: Laxey34
Post Number: 36
I can see quality on all E*3 SD Transponders with my Pansat 2700A. TP 12414 (92%) and I an in the caribbean. But I cannot see any quality on the TP with the HD channels.
Before thy change to HD I use to get quality on those TP's. I know the SR for those is 21500. I dont want to buy a HD Receiver and then I cant get the channels ... any ideas?
