Did pansat just go down?
Username: Pansad
Windsor, Ontario Canada
Post Number: 7
did they just scramble pansat or is it my machine?
Username: Metallica
Post Number: 818
it's your machine my is working fine..do you have the latest bin?
or try a Hard-Reboot on\off from the back.
Username: Pansad
Post Number: 8
tried that , my dish got hit pretty hard during the rain and hail storm. my switch crapped out from water damage and my dish had to be reaimed . i thought i had it solved, it worked great last night but i just turned it on and i get bad or scrambled channel or no signal so back to work i go i guess
Username: Jawalla
Orlando, FL USA
Post Number: 30
My Pansat Clone 2500 w/PUFF just went down for about 30 mins. Back up now.
