Username: Toney Antigua
Post Number: 53 Registered: Dec-05
Sunday, June 29, 2008 - 15:38 GMT Hello Everyone, I just did a blind scan on Echostar 3 this morning and I picked no Vertical Transponder on Echostar 3. Is anyone else experiencing this same problem, or is it just me? Looking forward to hear your reponse(s)and Thanks in advance for your response(s). toney.
Username: Plymouth Quebec city,
Quebec
Post Number: 2750 Registered: Jan-08
Sunday, June 29, 2008 - 16:32 GMT Check your cable connection between LNB and Switch. Lost Vertical is result of voltage lost
Username: Nydas Post Number: 10999 Registered: Jun-06
Sunday, June 29, 2008 - 17:27 GMT The conversion BINs used to have problems with vertical scan but that is not common now. An installation of an alternative BIN will solve the problem.
Post Number: 54 Registered: Dec-05
Wednesday, July 02, 2008 - 09:07 GMT Thanks Plymouth and Nalin Nyda for your responses. I really appreciate it. I will try your suggestions and get back to you on my findings. toney.
