DN Down?
Username: Boling
Post Number: 28
Is dish down?
Username: Metallica
Post Number: 798
Nope...DN still up
Do a Hard-Reboot.
Username: Bvvenegas
Post Number: 254
what does it mean when you loose some of your echo7 channels but not all of them i lost disc health and vh1 and some more i have bin 272 in my pansat 2700a orig can somebody point me in the right direction pleasr
Username: Metallica
Post Number: 799
humberto..go to channel edit delete all the channels on echo7..and rescan your echo7 again than you will get all of those channels back.
Username: Regio65
Monterrey, Nuevo Leon Mexico
Post Number: 316
SO THAT? THEY DO NOT READ POSTEAR BEFORE AND THUS THEY AVOID SPECULATIONS
Username: Bvvenegas
Post Number: 255
matallica the channels that im missing have no signal does that matter?
Username: Metallica
Post Number: 800
no it does not matter if those channels have no signal..because you already have most of the channel in echo7..you only missing a few channel...
delete all channels on echo7 than rescan it again...if you rescan it now still nothing....try it at night.."best time to rescan is night time"
Username: Bvvenegas
Post Number: 256
tried it at night and for some reason it does not get my missing channels and some ppv channels r there with a signal but they will not come out
Username: Mucho
Post Number: 343
humberto
Do a Factory Setting
User Setup
Blind Scan
If you still don't get all your channels
change your Bin 272.
People are having the same problem using
this Bin.
Username: Hshakarchi
Post Number: 231
BEV IS DOWN, HARD BOOT OR NOT, IT IS ON AUTOROLL .........
