A Problem, Any Advice?
Username: Dizasta
Post Number: 144
Hi,
I have two dishes setup for my SonicView Elite PVR and VS Pro box. One dish is 61.5 and one Nimiq 1.
61.5 is working fine while the other Nimiq 1 whenever I connect the LNB wire to the box's LCD screen goes to b and then boot and then just repeating boot and trying to reboot the box.
But when i disconnect that wire from the box, the box reboots properly and works fine.
Any advice or anyone else had that problem.
Username: Nydas
Post Number: 10936
Did you know that DN is up and BEV (Nimiq 1) was down and needs a new BIN?
Username: Extremex
Post Number: 224
Could be a short in the RG6 cable.
Username: Lroy
Post Number: 403
Yes could be a short in the cable, check both ends of the cable and ensure you have clean, good and proper connections. Good luck.
