Installing PCI O/I card
Username: Leines
Post Number: 90
Anyone ever had to install a PCI O/I card into a windows vista system... as soon as i add the hardware.. my system wont even boot inless its into safe mode...
any ideas?
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2596
Reinstall Vista Disk and do a repair
Username: King_of_sats
Post Number: 365
uninstall it it in safe mode and search the net for a updated driver.
Its obviously a driver issue. Beause when you boot in save mode only the basic drivers are loaded.
Username: Leines
Post Number: 92
Ok here are what im using..
I have a HP pavillion running windows vista home .
the card im trying to install is a SYBA PCI Multi I/O Controller SD-PCI-2S...
When i remove the card from the PCI slot and boot..the computer will boot normally...
If I put the card back into the computer, it wont boot in regular mode, i get bluescreen.. but it will boot into safe mode..
In both cases, the card isnt showing up in device manager under com cards..
Now when i first put the card into the system and install the driver in the box, it seemed to be working, but it was assigned to com port 8 and 9 and my loader for CW only had selections for up to com 6...
Should I remove the card, then boot the PC and remove the drivers... or should i just boot into safe mode and remove the driver??
Thanks for the help guys..
Username: Plymouth
Post Number: 2600
Remove the card and uninstall driver, reboot and install driver first, off comput and install card and boot.
On XP and Vista : install driver first and card.
If that not work do a search on site of card or forum on Yahoo or Google
Username: Leines
Post Number: 93
ok i got the card installed..and the driver going.. and vista is saying its working and ready to use.. but its working on COM 8 and COM 9... and my loader doesnt have a selection beyond COM 6.... how do i switch it...
Username: Plymouth
Post Number: 2602
Sorry leines i'm come back go in your driver and change it.
It's very difficult to help you without comput in face of me.
Do a search on site of card.
The site for your :
http://www.syba.com/Product/Info/Id/42
and manuel:
http://www.adeltek.com/Product%20Manual/PCI%20IO%20CONTROLLER/SD-PCI-2S.jpg
Maybe you can ghange it on upper slot on main board
good luck
