Need a little info. Viewsat 2000 platinum
Username: Rated08
Post Number: 31
I installed the latest bin, no picture. Q as no signal at all. Any ideas? Thanks
Username: Barry_obama
Muslim or Christian , Depends On crowd
Post Number: 12
try turning it on/off at back...does it say autorolling? can you get preview channels ch 100?
have you got the right bin?
make sure auto roll is turned on?
Post Number: 13
NO SIGNAL...CHECK SWITCH, BYPASS SWITCH, CHECK DISEQC SETTINGS ETC
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2564
Post your satellite setup
Username: Rated08
Post Number: 32
No channel 100 or 500.
Echostar 6.8 110.W
Antenna set up is...
LNB power-ON
LNB type- OCS-DP
LNB Freq.- 11250
22KHz-Off
TP Freq.- 12224
DiSEqC 1.0-Port 2
Legacy SW-none
Auto Roll is on !
Bin- DBPSW-080523P
Sorry for the second thread! accident! Thanks guys
Username: Plymouth
Post Number: 2565
Johnny Which dish and LNB?
You can try :LNB Type-standard and try to connect LNB directly without switch.
Reply if that not work
Thanks
