HL-P5085 NO PICTURE
Username: Samsjoint11
MIDDLEVILLE, MY US
PICTURE WILL TURN OFF ON FRONT OF SET A LIGHT BULB WITH BURST AROUND IT ON LEFT SIDE IS IT THE BULB? IT WILL TURN ON WORK FOR A WHIKE THEN TURN OFF WITH SAME WARNING NO NOISE
WHEN IT TURNS OFF IT GOES COMPLETELY DEAN
CAN'T HEAR FAN GOING AT ALL
THANKS
SEAN
Username: Ovadoggvo
Post Number: 156
Sean,
Buy a lamp! Sounds like a bulb issue. $109 at Discount-Merchant.com
It's worth a try!
