Original Pansat
Username: Ennio
Post Number: 38
A friend give me a original Pansat 2500A converted to 2700 should one use a 2500 file or a 2700 ??
Username: Lklives
Post Number: 15615
U MUST use files made especially for CONVERTED 2500-2700...they have not been created and released yet to fix this present ECM..but should be released in a few hours
they are in 2 formats...PUFF or B75...U can use either, based upon which boot file U use...
www.dssrookie.com is the best site for those files and info
here's the link to that specific area there..
http://www.dssrookie.com/forums/center-b-font-color-f8f8ff-size-1-fta-conversion -area-font-b-center/
Username: Ennio
Post Number: 39
Here the second (stupid) question: How do you know if is a puff or b75??
Thank for answer me!!
Username: Nydas
Post Number: 10532
When new Pansat conversion files come out, they will be posted.
Go to Menu/system info and find out exactly what you have.
You can post it here if you like.
Username: Lklives
Post Number: 15618
Thats why I gave U the link!
Username: Nydas
Post Number: 10534
You don't need a link to find out what you have.
Just go into menu/System info and post what you have.
Username: Ryersonresurrected
CANADA Charlatan...
Post Number: 1138
Hey Nalin, you assh0le. Why have you been badmouthing me since I went away? you scumbag!
Username: Jwl1
Post Number: 290
Ennino--not sure if you are asking how you know if the receiver is puff or b75 but if so, then you know by looking at system in the menu or booting the receiver. If it scolls Puff, then it's a puff. If you see numbers then it's b75.
However, if you are asking how to tell the difference between the two bins, it's in the labeling. You will be able to tell which is which.
