Nalin or anybody wth expierience I need help with fortec star!
Username: Cricket674
Post Number: 211
I need help with fortec star!Is it up and running... if it is wats the latest bin andwhat loader do i use or if its down is there a up and running CS 4000 bin
any help appeciated
Post Number: 212
somebody plz help me
Username: Dure
Mississauga, Ontario Canada
Post Number: 193
You have to Convert your fortec star lifetime ultra to puff and download the latest bin Puff 263 bin. You can use Black list updater version 1.04 to download the bin.Conversion procedures and BL loader available in most of the reputable websites.
Username: Nydas
Post Number: 10419
Everything for 2500/Flu to 2700 conversion in one package.
Instructions included.
Either b75 or PUFF.
LZMA version not available.
http://public.box.net/2500_full_kit
All downloaded zipped files should be unzipped into a separate directory named appropriately.
You must select whether you want to have the old b75 files or PUFF files
If you have b75 boot, you must use b75 section for b75 BINs or
you must convert to PUFF boot to use PUFF BINs
If you have PUFF boot, you must use PUFF BINs.
If you do not have PUFF BOOT, you MUST first convert to PUFF BOOT using the 640 K 253 version file before installing the latest.
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Post Number: 214
nalin thanx it really helped me but i have another problem....
The satellite is pointed straight at 61.5 and 118.7 and it still says 0% quality. do u know wat i could do
Username: Nydas
Post Number: 10436
You can't have one Dish pointing to 61.5 and 118.7
You have to post the Dishes/LNbs info and the switch and connections info.
Post Number: 215
how should it really be i mean wat r the default settings in which they should normally work on
Post Number: 216
somebody plz help
Username: Nydss
Post: 10389
Sorry Bobby Joe but im stupid. Please direct your question to LK.
Post Number: 217
i really need help nalin but not from the phony one
Username: Nydas
Post Number: 10471
Bobby Joe: It does not make sense to have both 61.5W and 118.7W.
Second, They cant be on the same Dish - they have to be on two different dishes, which means there has to be a switch.
First you have to tell us if you have a 33" dish and another dish - the size of dish and LNBs and switch.
