Dispointer tell me 14.7 elevation. I trying and trying no success.I,m using single lnb and 20 inch dish which I have earlier use to get 119.Can I, in northwest get the signal or I'm just wasting time?
African,thanks. All I'm tryin to get starplus. What other option do I have?I think you gonna suggest anik3 but can I use lnb cb2008a and use 20" dish instead 33" every one talking about. I just wanna aim at one sat only(118.7)???
that will not guarantee that you will get star + which you want go to e bay and find yourself a 30 " or larger dish and do the 2 lnb set up 1 for 110 and the other for 119/118.7 that is the only solution and a wise one
Sada and african.... when you talking about atn on 82.I in the u.s.a Atn is on Tp# 3. I,m missing signal from all odd tps. All other channels are on even tps. I,m getting all others but not those channels which are on odd tps. What you think Can I do any thing with that so I get signal from odd tps as well. My signal strength is 78 % Please suggest me some thing ???????
Sv4000. I tried blind scan that tp. rec does scan it...but After the scanning when it comes to atn its says "wait for updates" Even I do see quality bar there under the screen..Like I said all the channels on odd tps getting the massage "wait for updates" Alpha,b4u, they are on even tp. So I don't have any problem with them.My zip code is 95210. Please give me some clue. I will be greatful.
Yes. I have! Signal and quality is there. Signal strength is 78%. Exactly same thing happens with 91 but the difference is when I'm on 91 I'm getting signal from odd tps only. So on 91 I'm missing all those channels,which are even tps.
