Pansat 2500 Puff Conversions available
Username: Jwl1
Post Number: 264
The Pansat Puff conversion bin is available at Ftatalk (.com)
Username: Solex98
Northwest, WA United States
Post Number: 15
I think you're dreaming or you dearly want to watch TV. Nothing yet at FTATALK..
Username: Jwl1
Post Number: 266
AlexNA, I'm assuming you aren't looking in the right place, because the JVVH262 PUFF is exactly where I stated. In addition, it's been there for at least one hour.
Username: Adrenalyzer
Post Number: 37
any bin for P.S 2500-2700
Username: Jwl1
Post Number: 267
Ed mc-I assume you are referring to non Puff bins? As of now, no.
Username: Jatt_5abi
TorontoCanada
Post Number: 23
non puff bins are aviable at www.fta-future*info
Username: Jatt_5abi
TorontoCanada
Post Number: 24
joe i cant find puff bin need help
Post Number: 38
Hey man!!! i didn;t find the non puff bins at Future, can ya post the link.
thnks
Username: Jatt_5abi
TorontoCanada
Post Number: 25
non puff bin http://www.future-fta.info/Forums/attachment.php?attachmentid=12752&d=1207807697
Username: Jwl1
Post Number: 268
Go to Ftatalk (.com) scroll down to Pansat, make sure you are on the file only selection of the pansat section. Click on 2500..then you will see the bin posted 5 days ago for the non puff..and the new one posted right under it for the puff.
Username: Jatt_5abi
TorontoCanada
Post Number: 26
thanx
Username: Jwl1
Post Number: 269
Man--which bin were you referring to that in located on Future-FTA? When you said non-puff, I assumed the 2500-2700 conversion. If that is what you meant, then how would I find it, as I only see as far as 2700.
By the way, you are welcomed. Did you find it okay?
Username: Jwl1
Post Number: 270
Man-When I just went to look at Ftatalk (.com), I realized I forgot to tell you that you FIRST have to click FTA forums/discussions, whatever it says on the left of the page. Then you do scroll down and do the rest that I said.
Post Number: 40
hey MAN, wat bin did ya send me to, IT DON"T work, i need the P.S 2500-2700 bin
Username: Jaye50
Post Number: 95
fwank7_jwh-team-puff_262 from ftatalk works fine so far......thanx joe.....
Username: Letmeon
Post Number: 215
DSS-w*rld-co-nr has pufffffile
Username: Nydas
Post Number: 10085
Everything for 2500/Flu to 2700 conversion in one package.
Instructions included.
Either b75 or PUFF. LZMA version not available yet.
http://public.box.net/2500_full_kit
You must select whether you want to have the old b75 files or PUFF files or PUFF_LMZA FILES.
If you have b75 boot, you must use b75 section for b75 BINs or
you must convert to PUFF boot to use PUFF BINs
If you have PUFF boot, you must use PUFF BINs.
If you do not have PUFF BOOT, you MUST first conver to PUFF BOOT using the 640 K 253 version file before installing the latest.
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Post Number: 46
USE puff, DNload boot 60 1rst, with 2700-2500 loader, when finished DNloading, wait until you have knight rider lights, leave unit on.
THEN DNload puff cam am 253 bin,when finished DNload, then DON'T touch unit until it says on. Then turn unit off. Get latest puff bin-262, use loader, B.L 1.4.0. then turn on unit, and then it will read, P, then U, then F, then click write bin. When finished, wait until unit says on. Turn off, Then hook up to tv, do a blind scan 1rst, if your hitting more than 1 bird, then do sat scan on the rest. P.S Make sure you use all puff boot and bins, "K" Kool
