- THIS IS NOT AN LZMA FILE - DO A BLIND SCAN!! TO GEX MAXIMUM CHANNELS! - Will work for Pansat 2500 and Fortec remotes. - IF EXPERENCING REBOOTING TURN OF A/R (it will still roll) - IF EXPERENCING PROBLEMS LIKE NOT AS MANY CHANNELS DO A FACTORY RESET - This is Channel master compatible - Note That The Background Will Change -----------------------------------------------
[link removed]
I Posted this file because some people had problems when they turned off there box from there remote it would display a black screen and none of the cable channels would work. So this file fixes those issues.
the "Rat" has 136 posts and all used to bash Nalin , if you took LK's ballsack outta yur mouth for a sec ya mite be able to actually help someone , but yur not here to help anyone are ya
No sense posting anything here...cause Nalin and all her aliases, such as the Coders and all her others, just trash the place anyways...this site is useless..
fock ya, figure things out on yer own...I have my TV always...U need me, I don't need you!
If ya want good info, U come see me from now on...this playground never changes...just like Dishnet and the moles!
