No audio or video help plz
Username: Crank606
Post Number: 29
i had to do a factory default and when i scan channels under channel list it has echost1 echost2 so on and so forth i cant get any channels have a vs ultra 110 and 119
Username: Madflea168
Post Number: 400
explain details plz.
did you load the correct 080404 bin?
is all the antenna setting correct?
I assume this is not a fresh set up, but if so, is the antenna at the right angle?
Username: Crank606
Post Number: 30
yes i loaded correct bin and in antanna setup i cant seem to find lnb type where it should be ocs
Username: Crank606
Post Number: 31
and antenna is at right angle
Username: Crank606
Post Number: 32
ok under lnb type where it should be ocs the only options i have are standard and universal
