Having problem loading bin
Username: Kkbb7208
hello folks. i am sorry If i posted this on the wrong area>
but i am having problem loading the bins. onto pansat 2700a
I just got a new notebook. Compaq Pres. with Windows XP.I loaded the loader on computer, connected the usb cable, and its giving me a error "Cant open serial Port". I tried two different ports on the notebook.
any suggestions?
thnx in advance
Username: Nydas
Post Number: 9739
USB to serial convertors are notorious for problems and for slowness.
Buy only the type with its own installation CD.
Do not allow windows XP to install it.
Manually install using CD
Select COM1, or COM2, or COM3 or COM 4 port.
Use device manager in your computer to check and select the right port.
You will need a null modem cable as well
Username: Metallica
Post Number: 537
Chris...what serial port are you using in you PC look at that than use the same port in the loader....set your loader PORT the same as the PC port..than it will work.
Username: Kkbb7208
I tried all the ports with the loader and the PC but its still not recognizing.
Username: Kkbb7208
I also checked the device manager and its not showing anything such as ports or com ports.
Username: Doreenakadj
Ontario Canada
Post Number: 1404
on my laptop/notebook I use a docking center with a serial port try PORT #3 and Blacklist Updater v1.4 .... but on my desktop Pc using XP I use null modem cable PORT #1 Also if you are using a USB cable make sure you have USB2.0 installed on your notebook some older Compaq Pres. with Windows XP only use USB 1.0
Username: Metallica
Post Number: 543
Yuh..Chris you need to download the USB driver first so your notebook can recognize it first before you can use the loader...if your device manager did not show that mean your USB driver haven't install yet..or something is missing.
