110 W which echo is that ?
Username: Deptrai_cachon
Post Number: 86
hi guys .. 110 W is echo 8,10 or echo 6,8 ?>?
Username: Metallica
Post Number: 328
echo 8,10
Username: Birdwatcher
Post Number: 732
Its the echo in your as.ss
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 952
Metallica 110w is 6,8
Post Number: 733
plymouth its 8,10 you dumb bullshit
Username: Plymouth
Post Number: 953
Sorry i check on lyngsat and it's 8,10
On viewsat Ultra sat menu, it's write 6,8
that's why i says that.
Username: Lklives
Post Number: 14733
Echo 6 was replsced by echo 8
Username: Plymouth
Post Number: 955
Thanks LK
Username: Lklives
Post Number: 14734
actually my mistake above...echo 6 was replaced by echo 10
was echo 6 and 8...now its echo 8 and 10...all of these were/are at the 110 satellite
Username: Plymouth
Post Number: 956
Everyone can make errors
Username: Kirankumar
NO Bashing
Post Number: 2194
Ken,
this is a good hobby and you should do some reading to help yourself,like for channel and provider info and satellites go to www dot lyngsat dot com
and for dish alignment go to www.ftabins.com and go to the section for your receiver
i promise you you will learn a lot more that way
Post Number: 87
on my receiver 110 = echo 8,10
someonetold me 110 = echo 6,8
that's why i want to make sure
yeah
i went to dish pointer.com
it's pretty confusing ...
NO Bashing
Post Number: 2200
also go to lyngsat dot com
although your receiver says 8,10 it will pick up whatever is on lyngsat,
you just go ahead and scan 110 and don't worry about 8,10,6 or 8
because everything on 110 will come on
