Viewsat Extreme - Getting 110 and 119 but no 148 or 61.5
Username: Lapawnshop
Hello to all,
I have Viewsat Extreme and I am getting all the English channels but no Indian channels. Why is that? When I click on Installation/Antenna Setup and enter the setting..I do get 110 and 119. But when I work on 148 or 61.5 and change the ports I still see 110 and 119 and dont see 148 or 61.5. Why is that? I do have problem with Auto Rolling and Signal Searching. They just don't go away. Please help.
Username: Kirankumar
I will not b...
Post Number: 2125
post your antenna settings for all sats here so we can help
ECHO STAR 8, 10 = 110.W
LNB POWER = ON
LNB TYPE = OCS-DP
LNB FREQ = 11250
22 KHZ = OFF
TP = 12224
DISEQC 1.0 = PORT 2
MOTOR = OFF
LEGACY SW = NONE
ECHO STAR 7 = 119.W
LNB POWER = ON
LNB TYPE = OCS-DP
LNB FREQ = 11250
22 KHZ = OFF
TP = 12224
DISEQC 1.0 = PORT 1
MOTOR = OFF
LEGACY SW = NONE
ECHO STAR 1,2 = 148.W (Indian)
LNB POWER = ON
LNB TYPE = OCS-DP
LNB FREQ = 11250
22 KHZ = OFF
TP = 12603
DISEQC 1.0 = PORT 1
MOTOR = OFF
LEGACY SW = NONE
I am little confused about 148. Its on POrt 1 and on the top of the tv screen it shows 119 and when I change the port to port 2, it shows 110, and again on port 3 &4...again 119. PLease help
Plus... I dont see 118 on my receiver.
I will not b...
Post Number: 2127
ok change the port for echo 1,2 to 3.
then slowly change tp freq until you see 148 on top screen and save,
post results or questions
I was getting Indians Channels on 119 but after a while it started saying Searching Signals. Why is that?
I will not b...
Post Number: 2128
try my above post first,also try using TP freq 12326,for 148
we will deal with 118 later
I will not b...
Post Number: 2129
you were getting indian on 119 because 119 and 118 are very close and maybe you picked up some signal,don't worry about that for now
Sorry for the delay. I am not home right now. I will change the TP and will let you know. Thanks.
NO Bashing
Post Number: 2135
please post results for the benefit of other members
Username: Madflea168
Post Number: 333
if you are getting 110/119, how are you suppose to get 61 or 148 by just different setting and without move the antenna?
118 is not exist on vs sat list, you will either need to create one new sat or modify the 121, plus a dual lnb which accepts 118/119.
Username: Nydas
Post Number: 9200
la pawnshop: You have not mentioned if you have a second dish for 61.5W or for 148W.
If you have only one dish, then I suggest you stop wasting time and install another dish for 61.5W or for 148W. You can't get 119W,110W and 61.5w on one dish
You may get a few Indian channels on 119w, because there is a second sat close by at 118.7W. If you are interested in International channels, you should change your Dish and LNB to:
- 30-33" dish (about $50)
- LNB CB2008A for 118.7 and 119 (about $25)
- A standard Dual LNB for 110W (about $15)
- 1 or 2 DisEqC switches for one or two receivers. ($5-10 each)
If you want to go this route, ask "mad flea" to help you set it up when you have it installed.
Username: Abj
Post Number: 538
I have same feeling as you, Nalin. I think pawnshop has one dish. May be dish500.
Just not enough info to help.
Pawnshop if you have autorolling problem, you might want to do factory default and rescan. Just make sure you write down your antenna seting before you do the default. Once you do the default, go back into antenna setting and set the settings back as you had before you did the default. Then rescan the satellite...
Username: Abac
I have a pansat clone, but the same problem. I have lost all the Indian channels on Echo 119 (118.8W).
I did a hard boot and blind scan. May be I am missing something here. Need your help.
Username: Dsm
Waterloo
Please help: how to set polarization L or R on Viewsat. There are options of V or H only.
Thanks in advance
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 917
L is V
R is H
Post Number: 339
as,
make sure your antenna setting are correct, and you do get signal/quality on 118's first tp 11715 before you do the scan, otherwise chances are not gonna get much of the internationals.
Hello all,
I am getting all my Indian channels and English Channels. Here is my dish setup info:
LNB POWER = ON
LNB TYPE = OCS-DP
LNB FREQ = 11250
22 KHZ = OFF
TP = 12224
DISEQC 1.0 = PORT 2
MOTOR = OFF
LEGACY SW = NONE
ECHO STAR 7 = 119.W
LNB POWER = ON
LNB TYPE = OCS-DP
LNB FREQ = 11250
22 KHZ = OFF
TP = 12224
DISEQC 1.0 = PORT 1
MOTOR = OFF
LEGACY SW = NONE
LNB POWER = ON
LNB TYPE = OCS-DP
LNB FREQ = 11250
22 KHZ = OFF
TP = 12603
DISEQC 1.0 = PORT 1 ( I see 119 on top of my tv)
MOTOR = OFF
LEGACY SW = NONE
Now I have one another problem and it is that I am getting many duplicate channel on my TV Guide. Very annoying. Please help how to remove them. Thanks.
I am at work again and when I go home, I will post my latest dish setup info. Thanks.
Username: Abac
thanks mad flea
There are 42 TP settings that come up on the antenna setup window for echo 119. Some of them have signal strength upto 85 and some of them have 0. eg tp 12224 has 0 signal strength.
how does it go from here.
thanks
Username: Nydas
Post Number: 9246
You thin you are getting 148W, because that is what you set up in your Antenna setup.
You are actually getting 118.7W on Port 1 and also 119W.
Your valid TPs are still those for 118.7 (anik3) and 119w (Echo 7)
A lot of people have tried to explain to you but you are refusing to accept it.
Username: Abac
here is my antenna setup settings
LNB type: standard
LNB Freq.: 11250
22KHZ : off
Diseqc: #2
Legacy S/w : none
Skew : 0
TP : 1st TP 12224 V20.000
Level: 81%
Quality : 0 at TP12224, 40 to 80% on the balance
Could you pls help.
Post Number: 7
Nyda,
Everthing is working with my settings. But when I go home, I will post the correct setting so you can all look at it.
Also, can you please tell me what the correct should be? I am going to factory default it and re-scan all my channels.
Thanks.
Post Number: 340
as,
for 118, first you need to be sure you have the lnb for it. there are many posts about it in this forum.
as for the settings,
the settings you have in the post above is for the 119, 119 starts at 12239 with better signals, 12224 are most locals.
118 needs 10750 for lnb freq, either create new sat or delete 121 list, add tp 11715-20000-H-7/8, if you get signal/quality there, you will be able to get the rest of the tp in with regular scan.
good luck.
Username: Abac
Thanks Mad flea
I am a bit confused here now. I was getting all the channels on these settings before and suddenly it started dropping. The LNB is the same and I was scanning echo 119 (118.8).
I am not sure if the settings have changed now on its own or it is LNB that has gone bad. Is there a way to find that out. I can scan some of the channels but now all.
Do I need to change the LNB freq to make it work. Sorry for my limited knowledge and would need a lot of handholding here.
How and where do I start now?
thanks
Username: Nydas
Post Number: 9294
I will make one more attemt at amking you understand that any sat you select and connect to Port 1 will give you the same channels if you use these settings:
ECHO STAR 7 = 119.W
LNB POWER = ON
LNB TYPE = OCS-DP
LNB FREQ = 11250
22 KHZ = OFF
TP = 12224
DISEQC 1.0 = PORT 1
MOTOR = OFF
LEGACY SW = NONE
Try it using other sat names in your setup and scan and see and learn what happens.
Then post back here asking Mad Flea, about how to set up 118.7W and 119W properly.
Post Number: 346
as,
118 is circular, it is different than 119 linear, uses different lnb freq. the channels you scan on YOUR 118 with that settings is probably 119.
Username: Nestea
Post Number: 113
Change the LNB TYPE to universal or standard and not OCS-DP. If you do this all your channels will be working.
