Bronze Member Username: CanadiandudePost Number: 24 Registered: Jan-06 | Any one knows? what is the frequency for Zee sports? |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 907 Registered: Jan-08 | Zee sport #576 Echostar 3 12384 20000 H 5/6 V4386 A4387 P4386 |
Bronze Member Username: CanadiandudePost Number: 26 Registered: Jan-06 | on wat satelite,will it work on 148 west? |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 908 Registered: Jan-08 | Possible one moment i check |
Gold Member Username: KirankumarNO Bashing Post Number: 2170 Registered: Oct-07 | NO |
Bronze Member Username: CanadiandudePost Number: 27 Registered: Jan-06 | wat sattelite it works on? |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2859 Registered: Oct-07 | 119 and 61.5 |
Gold Member Username: KirankumarNO Bashing Post Number: 2171 Registered: Oct-07 | go here for all listings http://www.lyngsat*com/ remove star and replace with . |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 910 Registered: Jan-08 | On 119 and 61.5 like Sada says on #576 on both Sada do you have channel info |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2862 Registered: Oct-07 | same as you said above |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2863 Registered: Oct-07 | its indian sport channel and will show the upcomming cricket series b.w india and S.A. its also showing icl 20/20 matches. |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 911 Registered: Jan-08 | criquet also on nimiq 2 on #702 |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 912 Registered: Jan-08 | Sorry Criquet also on nimiq 2 on # 702 ZEE TV ATN |
Gold Member Username: Saqeeb9000Post Number: 2865 Registered: Oct-07 | you mean cricket yeh channel is cbn 82 west,, 702 |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 914 Registered: Jan-08 | Sada on # 702 i have Zee tv atn on my display |
Gold Member Username: Saqeeb9000Post Number: 2867 Registered: Oct-07 | sorry 730 is cbn channel that also shows cricket better than zee sports...... |
