Hi all, My current (new) setup is 3 LNBs with a switch box, it is pointed to DN 110, 119, 118. I am using a FLU converetd 2500 to 2700. My questios are: 1- After I upload the new bin file and select my 3 sats, do I need to edit any information on the sat details? I heard that "DiseqC" has to be numbered 1 to 3 for the 3 sats? is that true? anything else?
2 - For Sat 118, I was told that I need to create a new Sat (since it is not in my list) and have LNB Freq = 10750, anything else?
I appreciate your help if you let me know or point me to a link with this info.
on your diseqc switch, sat#1=port#1=119, sat#2=110, sat#3=118.
you can try to modify the 121 sat, delete all the TPs in 121 and add tp 11715-20000-H-7/8, if this not work, create the new sat is the second option, and still need to manually add the first tp.
DN contacted me to change my dish to a larger one (maybe dish 500?), it is larger than their regular ones. They took me off of 148 (for international) as they said DN is moving all international to 118 and added 110 & 119 for family package. So now I have 110, 118, and 119. It is a little hard for me now as in the past I used to upload the bin file and scan 148, then I am done. Now, I have to upload the bin file, update each sat individually and scan it. Then go find my favorite channels AGAIN from the hundreds of channels. I am still trying to catch up. I hope that answered your question :-)
good,you have the right size dish ,and dn should have installed a switch as well,so you just hook up their cable to fta box and adjust antenna settings and you should be good to go, also once you are set up you don't have to scan each time you load a new bin
I wish my friend, since I converted my Fortec to a Pansat clone (FLU converetd 2500 to 2700), everything goes away after you upload the new bin. Before I used to upload the new bin and everything is still there including the favorites lists.
