Need help with ViewSat Lite installtion
Username: Mooegypt2000
Hi guys
I have dish network 500 satellite hooked on 61.5 - 119 for Arabic channels
I purchase a new ViewSat Lite loaded the last updated file after scan it I get some off the channels that I had on my regular receiver.
I was told that I will get all channels listed on this web site because I'm still able to view it on regular receiver.
http://www.lyngsat*com/packages/dish61*html
Right now I have channels from 12428-12297-12384-12545-12603-12632-12661
And I need to get channels from 12326-12355-12414-12443-12472
What should I do to get my channels back?
Thank you
Username: One_eye_jack
Post Number: 439
hady
1) Factory Settings
2) Power or Blind Scan
hi Yukon
i did factory default than i loaded the 02/26/08 file then i reload latest bin file after rescan i get about 138 channels but no channel info ( names & guide ) and no video or audio and the menu display is different than before
Username: Kirankumar
Kenya
Post Number: 1775
hady,
post your settings
menu>satellite
Post Number: 443
hady
Menu display will depend on who's bin you used.
What Bin did you use?
Kenya
Post Number: 1779
hady,
load factory bin then load latest bin from ftabins
hi all
here is my Settings
i up loaded to this web site because i can't up loaded here it just pictures for my viewsat Settings
http://www.4shared.com/file/39141543/37238410/sat_pic.html
