NEW CAPTIVE-WORKS BINS FOR CW600P&CW700S&CW800S AT CRAZY
Username: Brucester
Post Number: 1296
new bin 174 fro the cw600p new bin 152 fro700s and new bin 152 fro cw800 enjoy all from crazyfta dot com free and frendly
Username: Brucester
Post Number: 1299
this bin is to Fixed Memory Leak so all cw boxes cw600p cw700s and cw800s of these modles should put the new bin in if not you will find later down the line things will get wors and you will have to find this fix so best to do it now to keep your boxes working proper thanks
Username: Leafs
Post Number: 498
captiveworks new files posted at www.ftasolutions.co.nr as well...
Username: Brucester
Post Number: 1300
donald trump start your own thread thanks quit hijacking my thread i dont doit to you but i will if you keep up fast free help come to crazyfta dot com thanks and injoy
Username: The_devil
Post Number: 146
does 1.74 work
Username: Jppatelahd
Post Number: 59
is this 1.74 bin working on captiveworks 600s premium on echostar 3 61.5 as of now...????
Post Number: 60
is this bin for fix memory leak???
whats that mean? can u explain BruceI please??
Username: Donnie1973
Post Number: 2741
u can put it in ur boxes and see...
Username: Afg_paramin
Post Number: 24
this ECM was for CW recievers
it was working too good
Username: Lebrimal
Post Number: 119
bruce, my men we need you.....
Username: Jwl1
Post Number: 218
If you need to reach Bruce sos, he's at Crazyfta (.com) most of the time. Therefore, if you go there, you just might find him there.
Username: Dishlover
Toronto, Ontario Canad
Post Number: 155
is cw working?
