USB to serial adapter that work with vista (Anyone)
Username: Ariza700
Markham, On Canada
Post Number: 37
Anyone,
Is there any USB to Serial that work with vista ???
Thx for your help in advance
Username: Way2smart
Www.desifta.tk
Post Number: 1238
go to ebay and write usd to serial for vista and they will show up....10 to 30 $
Username: Ariza700
Markham, On Canada
Post Number: 38
I bought one not from the e-bay but from a local store. the adapter says it will support windows XP and the sales guy told me if it work on XP than it will work on Vista but I am getting an E011 error when I try to download bin. Any suggestiions ?
thx
Username: Charjam
Post Number: 319
I have a cable from radio shack but it would only work for XP i bought one from best buy same thing then i went to ebay and got one for vista for 3.00andit works just loade bin 250 using it
Username: Statboy
Post Number: 71
Dude the USB to Serial will work on Vista even though it says only works on 98,2000 and XP. When you plug it into ur laptop (thats what i think ur doing) go into control panel and then system then device manger and find PORTS (COM & LPT) left click it then properties then go to andvanced and chage it to ur COMM port that ur using ( probably COM3) hope that helps.
Username: Kels
Post Number: 20
Belkin adapter works great!
Username: Imnycusa
Post Number: 120
try different ports. when i tried ports 1-3, i got error message. however, it finally worked on port #4. Also, i didnt have to install the driver from the disk, vista searched and found one from the installed drivers.
Username: Bvvenegas
Post Number: 212
I HAVE WINDOW VISTA AND I BOUGHT MY USB TO SERIAL CABLE AT COMPUSA AND IT WORKS BUT TAKE LIKE HALF HOUR TO DOWNLOAD THE BIN FILE TO THE PANSAT
Username: Imnycusa
Post Number: 121
same here humberto.
Username: Misc123
Google this driver for Windows Vista
usc1m-pl2303-usbdb9-vista.zip
It will work, trust me.
Username: Imnycusa
Post Number: 122
misc123, will it work better than vista installed driver?
Username: Ariza700
Markham, On Canada
Post Number: 39
Anyone,
I tried the driver recommanded by misc123 and it did not worked. I let vista to look for the driver but that did not work. When I plug the adapter in USB port, under device manager-USB controllers- unknown device shows up but it says no driver installed. Vista will not accept the drivers. Anyother suggestion???Thanks for your help in advance
Username: Misc123
I've uploaded the 2 mostly used drivers for the Serial-to-usb adaptors:
http://www.zshare.net/download/6616256a3a3f02/
vista_usb-driver.exe
http://www.zshare.net/download/7776347b421930/
I have installed the first one on 5-6 laptops with Vista Home with no problem but no luck with the second one. You may try both drivers and follow the instructions below:
STEP 1: Install the Software
First, download and install the driver.
STEP 2: Plug-in the Hardware
Connect the USB-to-Serial Adapter to your PC's USB port, and follow the on-screen instructions.
STEP 3: Set the Right COM Port
Right click on MY COMPUTER, then click PROPERTIES.
Click HARDWARE, then DEVICE MANAGER.
Double click PORTS (COM & LPT), and look for PROLIFIC USB-to-SERIAL Comm Port.
Double click that to open it.
Then click PORT SETTINGS, then ADVANCED.
Change the COM PORT NUMBER to COM1(or whatever COM PORT you want).
Then click OK.
If you get a warning message, click YES.
Then click OK, and close DEVICE MANAGER.
Finally, restart your PC.
Good Luck!
Username: Grearz
Post Number: 14
Just because it works in xp does not mean it will work with vista. I just had a *itch of a time in the past looking for a usb wireless stick that worked with vista reliably. Only found one, but just to let those that dont know that xp and vista are different.
I find some of the usb to serial cables tempermental. Data rates may be slow.
im sure in time it will get better, when everything catches up to being compatible with vista, then i might moved ahead with vista.
Username: Dssbss
Post Number: 8
this works for most
text/plainUpload
usb info.txt (2.0 k)
