i've looked at a couple of sites and some ebay listings for a rcvr...i was wondering how rampant clone/knockoff nfusion boxes are. Just was wondering before i take a serious look at them...thanks in advance
thanks...looking at that site, there are the two versions...one with the Wireless Ethernet Bridge and one without...is this for those that do not have wireless already set up in their homes? If one has wireless set up, do they need to purchase the Wireless Ethernet Bridge ?
TJ there are no clones for nfusion. u need wireless ethernet bridge which is called netgear. i will tell u how it works .. it is connected to internet so you need internet connection all the time to make it work. if your tv is close to ur comp (to ur wireless router). then u don't need netgear.. if your comp is far from ur rec lets says other room or upstairs.. then u need netgear
why buy an nfusion and stay connected to the net. When you could just buy a couple good boxes and run a in home cardshare for yourself. = (24/7) tv that you keep up yourself.
Thanks Guys, good thread, appreciate all the help...the t.v.s are upstairs and in other rooms so there will be a need for the wireless ethernet bridge...appreciate it.
